Автор Тема: Самодельный стружкосос или мой ответ буржуям  (Прочитано 253265 раз)
Re: Самодельный стружкосос или мой ответ буржуям
« Ответ #50 : Февраля 14, 2006, 10:49:01 am »
Вот нашёл ссылку Валерия на циклонный сайт.
Там параграф про статическое электричество такого содержания:
_________________________________________________________________________________
Static Electricity
There is always someone who will bring up the concerns about duct static potentially causing an explosion when you use PVC pipe. PVC pipe is an excellent insulator that will build up a static charge, particularly in a dry cold climate. Although that charge can shock you, the experts say it is not ample to cause an explosion in hobbyist based systems. Dr. Rod Cole wrote an excellent article in Fine Woodworking that debunked the static myth with PVC pipe. He also posted that article on a woodworking forum and gave me permission to include a link to his article. If you are still concerned, go read his information. Dr. Rod Cole has some excellent additional information on grounding PVC on his site: Dr. Rod Cole on Grounding PVC (Click here).
http://mywebpag...s/DC_myths.html
Explosion or not, getting a good zap while next to a sharp blade or cutter can be plenty dangerous, so if you live in a dry climate and chose to use PVC, you might want to seriously consider grounding your ducting. Running a single grounded wire around the outside of your PVC that also attaches to the metal coil spring inside your flex hose helps if you ground that wire both at your machine and your blower. However in dry climates, static can be a real pain around tools and doing a better job of grounding your dust collection piping is worth doing. As I said before most grounding approaches do not work well at all and often lead to plugged pipes. Here is a workable solution shared by one of the many contributors to this site. Thanks for sharing Brent!
Brent Dugan was the Maintenance Supervisor/Plant Engineer for a large 'Meltblown' polypropylene manufacturer (oil sorbents) for 9 years. He shared his way to eliminate those nasty static shocks, "Our product was plastic and our conveying systems, both air and mechanical were plastic. Polypropylene fibers traveling through 3" or 4" PVC piping creates massive amounts of static electricity. Our problem was so severe that we had sparks jumping 1 1/4" from our piping that would leave burn marks on your skin. Our employees dreaded working with the equipment. We tried all of the available methods you proposed and more; e.g., wire inside, wire outside, wrapped wire outside, etc. We spent quite a bit of my company's money to try and solve the problem with consultants and experts all to no avail.
I finally came up with a solution. It was so simple and inexpensive that you will not believe it. As you stated, static is electrons building on the surface of an object. Well, I solved the problem by sticking 2" wide aluminum foil tape to the outside and inside of the PVC piping and then grounding that tape. It is easy to just stick the tape on the outside of the pipe. Unfortunately that was not enough and I also had to put a strip of tape on the inside of the duct.
Putting the tape on the inside was an interesting challenge. I wanted my tape inside and tape outside to end up right next to each other with just the PVC in between so I could use a screw and nut to ground the two layers together. I was only able to make the aluminum tape with a backing like double-sided tape work on the inside. To do so I started by sticking the aluminum tape to the bottom edge of the PVC pipe. Slightly peel the backing and adhere the aluminum tape to the end of a piece of 1/2" EMT, conduit pipe, or other long rod. Feed the aluminum tape through the pipe as you unroll it from the roll. When you have the tape through the PVC, stick the aluminum tape to the end of the PVC pipe. Now 'tape' the backing to the rod then stretch the aluminum tape tightly angling it towards the top of the PVC piping (12 o'clock position). This keeps it from sticking prematurely. Now gently pull the rod out of the PVC that also removes the 'backing strip' off as you go. Keeping the aluminum tape stretched tightly lower it to the bottom side of the PVC pipe. To smooth it onto the inside I slipped in a longer piece of PVC and simply rolled that pipe inside to "iron" the aluminum tape down.
Having the tape back to back made grounding easy. I drilled a hole near each pipe end through both layers of foil, inserted a 1/4-20 screw from the inside of the pipe, put on a nut to make a good circuit, then connected each section using 14 gauge wire. I connected each end with alligator clips to another strip of the aluminum tape adhered to the concrete floor. That totally eliminated the massive static electrical discharges and earned me a bonus!"
Мож кто-то разберёт.
« Последнее редактирование: Февраля 14, 2006, 10:53:14 am от tsn »
Оффлайн Дми-III-й
« Ответ #51 : Февраля 14, 2006, 11:12:58 am »
Если в двух словах - товарищ предлагает наклеить металлизированный скотч по наружной и внутренней стороне  ПВХ трубы, соединять эти два слоя и заземлять. Технологию наклеивания скотча "внутрь" трубы я че-то уловить не смог, видимо с английским пока не очень.... Он предлагает кажется раскатать скотч внутри трубы клеем вверх, а потом перевернуть (то-ли трубу то-ли скотч)
С уважением, Дмитрий
Оффлайн SerzhSA
« Ответ #52 : Февраля 14, 2006, 11:21:41 am »
А ведь не зря буржуинские пылесосы выпускаются с заземляющим проводом в шнуре питания. И розетки соответствующие у них установлены. Это они  для нашего рынка устанавливают провод и вилку как у нас принято.
А для заземления шланга и исключения искрообразования достаточно обмотать его медной проволокой и через сопротивление 1МоМ подключить к заземленному пылесосу или в конце концов к трубе холодного водоснабжения.
Оффлайн Liki
  • Из: Мск
« Ответ #53 : Февраля 14, 2006, 11:43:05 am »
Там ещё предлагается, скоч который внутри трубы и с наружи соеденить между собой с помощью винта.
Человек должен думать, а машина работать!
« Ответ #54 : Февраля 14, 2006, 02:01:14 pm »
***Мож кто-то разберёт.***
Фигня. Со скотчем придумано для трубы, которая имеет жёсткие и ровные стенки. На гофрошланг скотч не намотаешь чтобы долго продержался, и уж тем более изнутри не приклеишь.
Оффлайн Дми-III-й
« Ответ #55 : Февраля 14, 2006, 03:13:05 pm »
Кстати справедливости ради хочу сказать что мой шланг из полиуретана практически не электризуется, хотя конечно такой пылесос как у меня не показатель - скорость потока маленькая, шланг всего три метра длиной, не заземлял, от проволоки шланга статикой пока ни разу не долбануло, да и стружка к стенкам шланга не прилипает. Возможно полиуретан электризуется гораздо меньше чем ПВХ.
Оффлайн stas.w
  • Самоделкин
  • Из: Литва
    • Мои фотки
« Ответ #56 : Февраля 17, 2006, 10:58:19 am »
Видео ролик про пылесос и самодельная насадку для уборки помещения мастерской:
 (~1.6Mb)
http://stas-w.d...p?id=11_0_1_0_M
« Последнее редактирование: Февраля 17, 2006, 06:23:02 pm от stas.w »
Оффлайн Дми-III-й
« Ответ #57 : Февраля 18, 2006, 02:36:17 pm »
Хорошая насадка в ролике про пылесос, и сам пылесос прсто мечта, а насадка самодельная или шла в комплекте с пылесосом?
Оффлайн stas.w
  • Самоделкин
  • Из: Литва
    • Мои фотки
« Ответ #58 : Февраля 18, 2006, 04:35:34 pm »
Сам сделал из старого вентиляцоного короба .
Размерил, разрезал, сварил полуавтоматом ,затем сформировам отверстие горловины ,вварил туда обрезок масленого фильтра жигулёвского ,на этот обрезок фильтр очень плотно вошла соединителная втулка для тех же шлангов .
Правда она угловая была ,я только половину от неё отрезал ,вторая пойдёт на подсоединение к станку (когда руки дойдут)http://www.jett...;P=p30&I=62
Внизу прикреплены резиновые полоски ,что бы не греметь о бетоный пол во время уборки .
« Последнее редактирование: Февраля 18, 2006, 08:11:11 pm от stas.w »
Оффлайн bulkin
« Ответ #59 : Февраля 18, 2006, 09:23:46 pm »
если Вы про бытовой пылесос, то мне думается, что сравнение некорректное. при уборке квартиры через шланг проходит гораздо меньший объем мусора, чем при работе рубанком или фрезером.
valery
« Ответ #60 : Февраля 18, 2006, 09:33:23 pm »
Стас, спасибо за ролик. Заодно услышал как эта прома работет.
« Ответ #61 : Февраля 19, 2006, 12:02:47 pm »
Вот ещё нашёл в прайсе Ками:
8   Гибкие воздуховоды из СЭВИЛЕНА
18455   Воздуховод  гофрированный из сэвилена для удаления стружки D=75 мм   124 руб
717   Воздуховод  гофрированный из сэвилена для удаления стружки D=100 мм   151 руб
18457   Воздуховод  гофрированный из сэвилена для удаления стружки D=125 мм   192 руб
18458   Воздуховод  гофрированный из сэвилена для удаления стружки D=160 мм   252 руб
9   Воздуховоды  из  пластичного ПВХ армированный ударопрочной спиралью WOODTEC
20838   Воздуховод из пластичного ПВХ армированный ударопрочной спиралью ф60 мм WOODTEC   144 руб
20128   Воздуховод из пластичного ПВХ армированный ударопрочной спиралью ф75 мм WOODTEC   202 руб
20129   Воздуховод из пластичного ПВХ армированный ударопрочной спиралью ф100 мм WOODTEC   288 руб
20130   Воздуховод из пластичного ПВХ армированный ударопрочной спиралью ф125 мм WOODTEC   374 руб
20131   Воздуховод из пластичного ПВХ армированный ударопрочной спиралью ф150 мм WOODTEC   547 руб
20132   Воздуховод из пластичного ПВХ армированный ударопрочной спиралью ф160 мм WOODTEC   634 руб
10   Воздуховоды ПРОЧЕЕ
10554   Металлорукав гофрированный (длина 3 м) для отсоса отходов д/о ф100 мм   200 руб
10555   Металлорукав гофрированный (длина 3 м) для отсоса отходов д/о ф125 мм   225 руб
Цены вроде поинтересней, потом они некий металлорукав продают, который, как пишут, годен для отсоса (интересно герметичный или нет?) - здесь проблем со статикой быть не должно да и цена приятная.
« Последнее редактирование: Февраля 19, 2006, 12:05:27 pm от tsn »
Оффлайн alex_k
« Ответ #62 : Февраля 25, 2006, 10:31:37 am »
у соседей нашел тему по вентиляции
http://www.mast...read.php?t=6223
посмотрел цены на канальные вентиляторы с расходом
http://www.blag...ru/td_ser.shtml
1300-1900  м3/ч и понял,  что это основная цена пылесоса.
если движка нет , то проще купить готовый.
Оффлайн Редан
« Ответ #63 : Марта 02, 2006, 07:09:49 am »
А я ответил буржуям так:
(бочка - от водогрейного котла советских времен - то, что называлось "Титан")
Пылесос 600Вт Вихрь. Это я к рейсмусу вынужден был сделать.
Оффлайн Дми-III-й
« Ответ #64 : Марта 02, 2006, 12:44:07 pm »
Классная конструкция, главное все просто и удобно. А чем ровно можно отрезать бак от титана, болгаркой резали, чем ровняли края?
А то у меня валяется два титана со схлопнувшейся трубой, хорошая идея их применить для сбора опилок.
Оффлайн Редан
« Ответ #65 : Марта 02, 2006, 07:55:39 pm »
Болгарки в хозяйстве нет, так как в основном столярничаем-плотничаем, потому резалось дисковой пилой с поставленным в нее болгарочным диском. Хотя можно и лобзиком с пилкой по металлу - но долго будет.
Оффлайн Дми-III-й
« Ответ #66 : Марта 13, 2006, 02:59:01 am »
Покой нам только снистя...
Приделал к пылесосу частотный инвертор (отдельное спасибо Антону (Avt) за разъяснения по настройке девайса), инвертор сам образует три фазы из однофазного напряжения, частоту питания двигателя теперь можно плавно изменять от 0 до ~130 Гц (дальше под нагрузкой не получается) а обороты соответственно от 0 до 7000 об./мин. (по паспорту было 2700 об./мин.), мощность за счет полноценного трехфазного питания выросла с 50 до 70 Вт, двигатель субъективно стал меньше нагреваться, стартует и останавливается с любой плавностью которую запрограммируешь, на максимальных оборотах агрегат теперь может собирать не только стружку, но и песок, даже мелкие металлические шайбы, если прислонить горловину шланга к руке, то шланг присасывается и так его можно приподнять на полметра :)
Заодно инвертор позволил сделать задержку остановки мотора после нажатия на кнопку "stop", это полезно если сделать проходную розетку для подключения инструментов, чтобы пылесос стартовал при включении нагрузки.
Также средствами инвертора удалось воплотить управление пуском и стартом в виде двух нефиксируемых кнопок с подсветкой как на "взрослых" станках (зеленая кнопка старта подсвечивается когда двигатель набрал положенные обороты, а красная кнопка - когда он полностью остановился) и выбор пяти фиксированных скоростей переключателем плюс режим плавной регулировки.
Сантехнические резиновые муфты приклеены узкой частью к шлангу, дают плотную посадку шланга на диаметры от 55 до 60 мм за счет того что немного сжимают гофру, а если их вывернуть наизнанку т.е. широкий край муфты отворачивается в сторону конца шланга, то получается резиновый переходник, который можно сажать на диаметр 80-85 мм.
« Последнее редактирование: Апреля 05, 2006, 11:20:13 am от Дми-III-й »
Оффлайн ignel
  • Игорь
  • Administrator
  • Из: Надым, ЯНАО
  • UB8KAA
    • форум "Мастеровой"
« Ответ #67 : Марта 13, 2006, 09:03:39 am »
А где можно поподробнее почитать про этот инвертер (характеристики, мощность, возможности, цена)?
« Ответ #68 : Марта 13, 2006, 10:13:04 am »
А инвертор стоит не дороже ли энкоровского пылеотсоса?
Оффлайн Дми-III-й
« Ответ #69 : Марта 13, 2006, 10:48:49 am »
Вот здесь есть каталог: http://tosvert....talog/elid_455/
Я взял 200 Ваттную модель VF-nC1 2002P, цена конечно не шибко радостная, но он того стоит, не думал что асинхронник способен на такое, на малых оборотах может крутиться почти без потери крутящего момента, отдал за него 4400, но пока не пожалел об этом, правда мой пылесос по цене уже сравнялся с энкоровским Корветом, зато уже со шлангом, компактнее и тише, можно дома вечером включать, за это ИМХО можно и переплатить.
Думаю в дальнейшем купить еще один инвертор для самодельного токарного станочка, можно будет сильно упростить конструкцию, не мудрить с вариатором и сделать все управление электронным, у него есть возможность установить 16 фиксированных скоростей и переключать их или менять скорость плавно.
« Последнее редактирование: Марта 13, 2006, 10:52:49 am от Дми-III-й »
« Ответ #70 : Марта 13, 2006, 11:35:31 am »
***зато уже со шлангом, компактнее и тише, можно дома вечером включать, за это ИМХО можно и переплатить.***
А на работающую с ним в комплекте циркулярку поставить резиновые редуктор и диск, чтобы тоже по ночам можно было включать и не шуметь?..
Оффлайн Дми-III-й
« Ответ #71 : Марта 13, 2006, 12:37:57 pm »
Да, циркуляркой по ночам работать жестоко :) Просто я все проксоном и резьбой по ночам балуюсь, раньше приходилось бегать с веником по углам и собирать, пять минут поковырял - подмел.
« Ответ #72 : Марта 13, 2006, 02:12:42 pm »
***Просто я все проксоном и резьбой по ночам балуюсь***
Эк вас, батенька, угораздило - днем на подобные занятия времени нет? Только по ночам, когда СПАТЬ положено?
Оффлайн Дми-III-й
« Ответ #73 : Марта 13, 2006, 04:19:06 pm »
Увы. Днем на работе, только и остается что по ночам и в выходные.
« Ответ #74 : Марта 14, 2006, 09:22:39 am »
***Днем на работе, только и остается что по ночам и в выходные.***
И у вас смотрю та же проблема - почему в сутках не 36 часов?..
29 Ответов
15460 Просмотров
Последний ответ Сентября 23, 2015, 10:01:34 pm
от palisandrs
19 Ответов
243705 Просмотров
Последний ответ Июня 06, 2011, 10:19:36 pm
от Mazai
3955 Ответов
846128 Просмотров
Последний ответ Января 12, 2018, 09:07:09 pm
от михуил
58 Ответов
26914 Просмотров
Последний ответ Августа 12, 2014, 02:04:08 am
от Brain
2679 Просмотров
Последний ответ Декабря 06, 2011, 11:28:27 am
от сергей ssvi
