Автор Тема: Стол для фрезера, с позиционером и лифтом INCRA.  (Прочитано 86003 раз)
Оффлайн Fdr
  • Можно просто-дядя Фёдор
    • "Japan Tools" Японский ручной столярный инструмент
Re: Стол для фрезера, с позиционером и лифтом INCRA.
« Ответ #50 : Февраля 13, 2013, 12:44:07 pm »
я не понял как скорость регулируется.
Work at the best speed for the router bit and the wood you are using.
Reduces speed without reducing torque! Electronic feedback maintains speed by increasing voltage to motor as load increases.
NEW & IMPROVED! Heavy Duty Speed Control features better circuitry and heavier components! Simply plug in speed control then plug your router into the speed control. Adjust speed from 0 RPM to full speed. The Heavy Duty Speed Control features an aluminum case, and is recommended for industrial and commercial use. The high impact plastic Standard Duty Speed Control has exactly the same features and is suitable for home shops.
• Less tear out • Stops burning
• Feed at comfortable rate
• Better, safer results with large diameter panel raising bits
• Less wear on bits • Less noise
• Softer starts at lower speeds
• Adjustable speed from 0 RPM to full speed
• 3 position rocker switch- Variable / Off / Full Speed
• Full power and torque at all speeds
• Go back and forth from any preset speed to full speed at the flip of a switch
• Works with most routers 3-1/4 HP or less
• 120V • Give your router a feature only available on expensive routers
• Easy to use- Simply plug in speed control and plug your router into the speed control- turn dial slowly for best results. (Speed control has a clip that can be worn on your belt, hung on wall, or left loose)
. • Dust Cover Included (not shown in photo) NOTE: Will not work with soft start or variable speed routers. Will not work with "AC capacitor start induction" type motors.
Оффлайн z2
  • Из: Киров
« Ответ #51 : Февраля 13, 2013, 12:50:07 pm »
может, там частотник?
Не знаю. Написал им письмо с вопросами, будем ждать ответа.
Вещи действительно не такие какими кажутся. (с)
Оффлайн Fdr
« Ответ #52 : Февраля 13, 2013, 04:05:21 pm »
  Эх, говорила старушка мама: "Сынок, прежде чем Гуглить, воспользуйся местным поиском на сайте"  )))
Уже есть первопроходец: shraik с января уже имеет.  Вот он то всё и разъяснит!
 Тема: Моторизованный лифт от MLCS
http://forum.woodtools.ru/index.php?topic=39468.0;all
Re: Моторизованный лифт от MLCS
« Ответ #4 : Января 22, 2012, 05:37:45 pm »
Да метрику и дюймы показывает,фиксируется кнопкой hold.
И просто так ,плюс работает от сети 220 и 120 вольт!
О моторе:
Большой портер - это 7518 и 7519.
Первый 5 скоростей 10 13 16 19 21, второй одна скорость 22.
Porter Cable PC690, 890 series Dewalt DWD616, Bosch 1617EVS, 1618EVS, CRAFTSMAN 320.17543
-эти модели перечислены на сайте и написано что подходят все другие, диаметром 3,5 дюйма
Если заказывать напрямую на сайте, цена с доставкой в Россию 502 доллара 40 центов,
до 22 января доставка была дешевле, почта сша подняла тарифы
Оффлайн z2
  • Из: Киров
« Ответ #53 : Февраля 14, 2013, 12:33:01 pm »
А мне не говорила ((( Я же тему про этот лифт не начинал, поэтому ничего и не искал по форуму. А буржуи тем временем нас вежливо послали с нашими 220 вольтами.
The router speed is controlled independent of the Powerlift. The speed and direction controls on the control box for the Powerlift are to control the stepper motor on the lift to change the up and down motion and the speed of travel. We do not have a product available to vary the speed of your 220V router. Both of our router speed controls are designed to control 110V universal brush type motors.
Всё-таки форум - замечательная вещь, а когда ещё люди добрые подскажут - вообще хорошо )))
Прочитал я отзывы владельца, и нашёл ключевую фразу:
Тайвань всё конечно грубовато по сравнению с инкрой и вудпекером,но мне надо ехать,а не шашечки.
поскольку мне не ехать, а именно шашечки, забудем про эту железку, и вернемся к Инкре ))
« Последнее редактирование: Февраля 14, 2013, 12:44:33 pm от z2 »
Оффлайн z2
  • Из: Киров
« Ответ #54 : Февраля 15, 2013, 05:24:31 pm »
Пока до Инкры руки не доходят, переделываю старый столик. Поставил направляющую 19 мм. в стол, и направляющую под крепеж в упор. Теперь можно использовать шипорезную каретку, угловой упор и "расчески".
Что-то фотографии грузить не хочет, всего по 40 Кб. а не проходят. Сейчас на Яндек выложу.
«Фрезерный стол.» на Яндекс.Фотках
«Шипорезная каретка.» на Яндекс.Фотках
«Угловой упор.» на Яндекс.Фотках
«Прижим.» на Яндекс.Фотках
Русская инструкция к позиционеру Incra http://yadi.sk/d/JlFyX14d2dElB
« Последнее редактирование: Февраля 15, 2013, 11:42:59 pm от z2 »
Оффлайн z2
  • Из: Киров
« Ответ #55 : Февраля 16, 2013, 07:26:50 pm »
Беда, помогайте. Собрал я позиционер. Там одна деталь есть - основа дополнительного упора. Она оказалась кривая, и угол дополнительного упора по отношению к упору Wonder Fence совсем не 90 градусов а меньше. Это брак? Если брак то как мне с этой штуковины миллиметра три по торцу наискосок срезать ((( Я боюсь что на торцовке точно угол тоже не выставлю.
Оффлайн T34
« Ответ #56 : Февраля 16, 2013, 09:11:52 pm »
Никакой торцовки ты че?! Только шлифовка, там же дюраль, сделай оснастку чтобы 90 градусов держала и по шкурочке вжик вжик вжик вжик
А там нет юстировочки? Может шайбочку подложить? А в другую сторону собрать не примее?
« Последнее редактирование: Февраля 16, 2013, 09:14:20 pm от T34 »
Оффлайн z2
  • Из: Киров
« Ответ #57 : Февраля 16, 2013, 09:38:23 pm »
Она в обе стороны одинаково кривая. Шайбы попробую, если не получится буду искать промышленный фрезер.
У меня есть пила Nielsen для идеального распила алюминиевого багета, но эта деталь слишком толстая для нее. Попробую прикинуть нельзя ли за два прохода с разных сторон.
« Последнее редактирование: Февраля 16, 2013, 09:42:09 pm от z2 »
Оффлайн T34
« Ответ #58 : Февраля 16, 2013, 10:56:40 pm »
Я бы шлифовал...
Оффлайн z2
  • Из: Киров
« Ответ #59 : Февраля 18, 2013, 07:45:12 pm »
Я бы шлифовал...
Всё-таки  фрезер с ЧПУ - вещь! Нашел фрезу на 70 мм. и потихонечку снял ненужное. Получилось идеально ровно.
Оффлайн Caterpillar
  • Олег
  • Из: Москва-ЮБутово
« Ответ #60 : Февраля 18, 2013, 08:19:44 pm »
Если я правильно понял, то нет 90 градусов между  Wonder Fence и упором для фрезеровки шипов, который на  Wonder Fence вешается. Если так, то там всё регулируется тремя пластиковыми винтами. Приставляете угольник и потихоньку затягиваете в этом положении. Угол 90 градусов ровно.
Оффлайн z2
  • Из: Киров
« Ответ #61 : Февраля 18, 2013, 09:00:59 pm »
Теперь можно все винты затянуть одинаково и будет прямой угол ))) я потом этот узел полностью переделаю, не гоже ему двуми фанерками по столу скользить. Сделаю подошву из капралона и пущу его по направляющей.
Оффлайн T34
« Ответ #62 : Февраля 19, 2013, 07:44:52 am »
прямоту кривой инкры, проверяем угольником инкры:)... похоже на коррупционный сговор:)))))) а в целом я рад что все получилось. Это правильно, когда вещь прямая изначально, то и не фиг юстировать, а если есть чем поправить, то и в двойне хорошо ее спрямить!
Оффлайн Саня Альфа
« Ответ #63 : Февраля 28, 2013, 12:40:36 pm »
 В "Калпа Врикше" есть микролифт INKRA.
Какие модели фрезера туда можно установить ?
На странице в магазине никаких пояснений...
Оффлайн Ataka
  • Из: Пушкино МО
    • Грузовые перевозки по Москве. Перевозка вещей, дачные перевозки.
« Ответ #64 : Февраля 28, 2013, 01:16:03 pm »
Например вот такой
Оффлайн z2
  • Из: Киров
« Ответ #65 : Февраля 28, 2013, 01:19:19 pm »
Там продается Лифт Incra Mat-R-Lift II такой же как у меня. К нему подходит почти любой круглый фрезер. Например Бош 1400.
Оффлайн Саня Альфа
« Ответ #66 : Марта 01, 2013, 04:48:02 pm »
Спасибо за ответы !!!
Микролифт - штуковина очень полезная !
Оффлайн z2
  • Из: Киров
« Ответ #67 : Марта 15, 2013, 05:46:39 pm »
Извиняюсь что не так быстро, но... начали делать сам столик. Продолжение следует.
Оффлайн dachnik2
  • Павел
« Ответ #68 : Марта 15, 2013, 06:10:59 pm »
 Стол из брашированной сосны  :good: жду продолжения
Моя мастерская http://forum.wo...p?topic=44202.0 мои работы http://forum.wo...p?topic=44792.0.                       Мечты должны сбываться вовремя ...  https://www.ins...m.com/voinovpd/ ЭО
Оффлайн Amir
  • Из: Уфа
« Ответ #69 : Марта 15, 2013, 06:57:07 pm »
Завидую Вашей аккуратности. Такие чистые линии для сугубо утилитарного предмета !!!!!
Такое чувство, что для музея современного искусства делаете )))).
Оффлайн T34
« Ответ #70 : Марта 15, 2013, 07:00:18 pm »
вот и признание пришло:) А ты все говорил центр не точно, припуски 0.01 не выходят:)... Смотрю я на этот решетчатый каркас и вижу что точности достигнуты прям металлические, удовлетворен?
Оффлайн z2
  • Из: Киров
« Ответ #71 : Марта 15, 2013, 07:13:47 pm »
не совсем. В итоге на шлифовку ушло 0,8% от общих размеров. Но тут есть некоторые наши ошибки, которые мы учтем в следующем изделии.
В человеке должно быть всё прекрасно, и душа, и мысли, и фрезерный стол  :D
« Последнее редактирование: Марта 15, 2013, 07:15:24 pm от z2 »
Оффлайн Tehdoors
    • door.okis.ru
« Ответ #72 : Марта 15, 2013, 08:16:31 pm »
Хорошая мастерская :ok: этакий, уголок в стиле хай-тек.
Предвидится элегантный столик, вижу куча мест под ящички.
Ждём продолжение :)
Оффлайн z2
  • Из: Киров
« Ответ #73 : Марта 16, 2013, 06:28:48 pm »
Склеил. Покрасил на первый раз.
Оффлайн Иван Василич
  • он же ipexe
  • Из: Москва, Зеленоград
« Ответ #74 : Марта 17, 2013, 07:20:30 pm »
Добрый день! Подскажите как у Mast-R-Lift II реализована подстройка соосности столешницы с пластиной лифта?
« Последнее редактирование: Марта 17, 2013, 07:24:21 pm от ipexe »
3656 Ответов
3077618 Просмотров
Последний ответ Сегодня в 09:03:26 pm
от sirota0
60 Ответов
50751 Просмотров
Последний ответ Октября 05, 2006, 10:41:21 am
от ao
19 Ответов
13206 Просмотров
Последний ответ Декабря 28, 2010, 11:11:15 pm
от WoodBed
38 Ответов
26033 Просмотров
Последний ответ Сентября 29, 2012, 09:09:33 pm
от Only17
18848 Просмотров
Последний ответ Сентября 17, 2012, 04:55:22 pm
от Spadar
