Автор Тема: ВИДЕО: The Versatile Router (Фрезер - универсальный инструмент)  (Прочитано 15787 раз)
Оффлайн alarbacn
  • Из: Brazil
The Versatile Router (VideO)
Get the Most Out of Your Router
by Pat Warner *
Woodworkers of every skill level will find something useful in this DVD about the most versatile power tool in the shop. For router expert Pat Warner, the basic idea is to use the router as a "finishing" tool: do all your rough-cutting and hogging with other power tools, then remove the last 1/32 in. of wood with the router, in a clean, surgical stroke.
Warner shows you how to rout clean circles and holes; how to make half-lap joints at the ends of boards, and laps in the middle of boards that cross each other at any angle you choose. There's a section on the anatomy of a fixed-base router, another on the use of the collar guide for precise template work, and a lesson on getting two different shapes from the same decorative-profile bit.
Warner explains how to get the most out of your router. He shows you how to rout perfect dadoes and grooves, how to make through mortises without tearout, and how to set up and use the table-mounted router.
You'll also learn all about bearing-guided bits, how to rout sliding dovetails, and how to manage full-thickness cuts to make edge treatments like bullnoses.
* - Pat Warner is a designer, craftsman, and well-known author of many articles and books including Getting the Very Best from Your Router and The Router Book.
Router_The Versatile
.avi  >  00:47:54  > 493MB
Video: DivX 5 720x528 29.97fps
Audio: MPEG Audio Layer 3 48000Hz stereo 128Kbps
:good: Até mais
« Последнее редактирование: Марта 31, 2011, 10:45:56 pm от Foundry »
Оффлайн Роман Снеговских
  • Из: Иркутск
  • живые деревья так прекрасны
771 Ответов
401425 Просмотров
Последний ответ Мая 30, 2018, 11:54:19 pm
от кастет
10035 Просмотров
Последний ответ Апреля 17, 2006, 01:37:21 pm
от Iroko
7998 Просмотров
Последний ответ Мая 17, 2010, 10:39:51 am
от alarbacn
6126 Просмотров
Последний ответ Сентября 02, 2011, 04:59:58 pm
8630 Просмотров
Последний ответ Августа 25, 2011, 09:23:10 pm
от Артурыч
